System 3 Silvertip Epoxy Kits
S3-100
$79.50 - $764.80
One benefit of System Three SilverTip Resin is its non-blush quality. Even at low temperatures and high humidity, this resin will not blush. This means you don't have to wipe down the cured epoxy between coats which will save you time and energy better spent building your boat. S3 Silvertip also allows more time between coats without resanding. There is also a longer working time with this resin, but not an extended cure time. So, you have more time to apply it properly without taking longer to complete your project.
You pay a premium, but we think Silvertip is the best epoxy on the market.
