SilverTip GelMagic--Choose size above
GelMagic is a toughened, non-sagging, two component, structural epoxy adhesive designed for superior bonding to wood and most porous materials. It is unique in that it starts as two self-leveling liquids, which form a soft, thixotropic, sag-resistant paste when mixed. Measuring is easily accomplished by either volume or weight. GelMagic requires no additional modification with fillers and can be applied to vertical and overhead surfaces without running, eliminating the mess and waste associated with other epoxies. GelMagic exhibits exceptionally high peel strength and employs a state of the art, two-phase epoxy morphology, which creates an adhesive bond that is tougher, more resistant to embrittlement and has better elevated temperature properties than other room temperature cured epoxy adhesives. GelMagic can be post-cured up to 140°F for even greater performance.
Recommended Uses:
Specifically designed for optimum adhesive properties. Not a general-purpose resin made for coating and then modified with filler to act as an adhesive. When fully cured, it is unaffected by water, oil, kerosene, and many other chemicals. It will not stain wood and is immune to fungus and rot. GelMagic is ideal for stitch-and-glue, plywood, strip built and glued lap strake construction. Also use GelMagic as a high strength, gap filling, waterproof adhesive for general woodworking and architectural applications.
Application:
Mixed at a 2 to 1 by volume ratio, GelMagic will cure at temperatures as low as 35°F. Two color component system aids in determining a complete mix. Mixes to a pre-thickened, non-sagging state. No fillers needed.
Available Color:
Resin (part A): Blue
Hardener (part B): Amber
Mixed Color: Tan
NOTE: This item is considered Hazardous for shipping purposes, so it cannot be shipped outside the USA. Shipping within the US is by ground. For 2-day or 3-day shipping in the US, there is an additional $30 fee per package.
System Three SilverTip GelMagic Kits
$29.95
