Basic Electrical Design - DC for Boats 23 to 30 feet PDF
EL-300-SDC
$60.00
This simple DC system is a minimal system you might use in a power boat with only very minimal equipment such as a dayboat with no overnight capability. The power distribution will use a small fuseblock instead of a circuit breaker based panel. It will contain navigation lights (which may be an option for the boat), a bilge pump and some capability for engine instruments and a radio.
Zip
Zip
$169.00 - $4,921.00
