Outboard/Inboard/IO - Shorepower only: This system is circuit breaker based and contains the wiring for a system that is useful for multiple day cruising with a complete equipment package for open or cuddy cabin boats up to 30 feet LOA.
Electrical Design - Shorepower for Cabin or Open Boats 23 to 30 feet PDF
            $45.00
