Basic Electrical Design - DC for Boats up to 23 feet PDF
EL-210-SDC
$50.00
This simple DC system is a minimal system you might use in a power boat with only very minimal equipment such as a dayboat with no overnight capability. The power distribution will use a small fuseblock instead of a circuit breaker based panel. It will contain navigation lights (which may be an option for the boat), a bilge pump and some capability for engine instruments and a radio.
